78 f150 302 vacuum diagram
3
i have a 1978 f150 2wd 302 2 barrel carb and a auto trans. does anyone have the vacuum diagram for this truck? and can I take off the stock air cleaner and just block the vacuum lines? thanks in advance josh
They can be plugged...But for a cleaner look and less lightly to leak, i will rerun new lines voiding out the air cleaner...that is if im going to a aftermarket performance style air cleaner...
3
thanks I wanted to go with an aftermarket air cleaner and I didn't know it would run bad without it hooked up and I needed the vacuum diagram because there are vacuum hoses not plugged into ports and I don't know where they go.
I'm pretty sure you need diagram 8-54G-R0
I have it here somewhere.
3
thanks it would be really helpful
