- 6
- 0
Hello:
I have a 1976 F-250 that had been sitting for a couple years, and I recently got it running again. Immediately I discovered two brake problems. There was a leak with the front driver's side line, and the rear passenger's side brake cylinder was also leaking (fluid coming from within the drum). So, I replaced the front driver's side line and bled it, everything was fine there. I replaced the rear cylinder and also replaced both rear lines from the Y connector to each side, because they were in rough shape. Now, I cannot get the rear brakes to bleed. I've tried manually bleeding with somebody pushing on the pedal without the engine running, but nothing comes out of the bleeder screw on either side. I also started the truck and pressed the brake and still nothing.
Can anybody offer any suggestion as to how to get this to bleed the rear brakes? Thanks in advance!
