- 55
Hi all, Currently up for sale is
1 Steering column in very good working order,automatic column shift,ts switch,horn electrics works,column mounted neutral safety,will work on trans mounted safety switch vehicles simply you just do not use it. excellant steering wheel and leather no rips or tears.$65.00 +shipping
1 pair door panels green in color 1 small hole in drivers panel size of a sheet metal screw,can be plugged with a vinal fastener.small hole in passengers above the speaker grille hardly noticeable but i telling it like it is.these panels are very clean otherwise. $ 60.00 + shipping
Items came from a 77 F150 running doner vehicle in pretty decent condition for its age it was used to complete my 79
1 pair inner fenders some scale but solid no rust through holes! blue grommet standard ignition module does work,horn relay has been removed 40.00 +shipping
1 pair factory fenders these are salvageable solid pieces minor pits no rust through holes,drivers does have a dent in the lower front but can be worked out 35.00 + shipping
