7.3 f35rough idle
my 2001 7.3 powerstroke starts really rough and has no power when it sits over night or for long periods of time. after 20 minutes of warm up it runs like its brand new. anybody have any input or ideas to help? i've had it into a mechanic and 2 different ford dealers and the only thing they could do was charge me......
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
Welcome to FTF! :wavey:
As far as your question, I can't answer that because I don't know much about them.
Somebody around here should be able to help you though! YelloThumbUp
Are the glow plugs operating correctly? For a diesel to run correctly, there needs to be adequate heat in the combustion chamber.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
If it's cold out the waste gate will stay closed restricting power untill up to normal operating temp. You may also have issues with the glow plugs if it runs rough or starts hard when cold.
blackhat620
You Had to be There
1,687
150
Arizona
First thought was glow plugs not working and/or injector problems.
How many miles on the engine?
4r100-3
Liquid Goodness
63
Washington
Check your batteries. Low batteries on these trucks does funny things. Then check the GP relay. Your UVC harness may be coming lose as well. Which could also be a cause to not all glow plugs lighting up. Bluish/black smoke right after startup?
