6.7 specs
Item Specification
General Specifications — Engine
Displacement 6.7L (409 cu in)
Number of cylinders 8
Bore 99 mm (3.897 in)
Stroke 108 mm (4.251 in)
Firing order 1-3-7-2-6-5-4-8
Oil pressure — minimum 68.9 kPa (10 psi) at 700 rpm, 137.8 kPa (20 psi) at 1,200 rpm, 241.3 kPa (35 psi) at 1,800 rpm with engine at operating temperature
Oil capacity 12.3L (13 qt) with filter
Compression ratio 16.2:1
Engine weight (without accessory drive components) 445 kg (981 lb)
Cylinder head and valve train
Cylinder head gasket surface flatness — overall 0.4 mm (0.015 in)
Combustion chamber volume 55.7 cc
Valve arrangement (front to rear) I-E-I-E-I-E-I-E
Valve guide bore diameter 7.035-7.075 mm
