- 4
- 0
Hi I've got a 2wd 07 f-150 with a 5.4 in it and I'm trying to find out if it would be possible to change the thrust washer and main crankshaft bearings without removing the engine . Thanks in advance
I suppose anything is possible, advisable? NO. To change main bearings, you need the crankshaft to be loose from the block. One end has the timing chains attached, the other end has the flywheel/converter attached. When you drop the crank, you'll deform the rear main seal, possibly creating a failure there. Because of the 2 wheel drive nature, you won't have much room to see if you're installing everything properly, or torque wrench maneuverability. My opinion, too risky.Hi I've got a 2wd 07 f-150 with a 5.4 in it and I'm trying to find out if it would be possible to change the thrust washer and main crankshaft bearings without removing the engine . Thanks in advance
