5.4l 3v Broken Spark Plug Removal Method
makuloco2000
Certified Ford Tech
177
23
So yes I am following the method Lisle spells out but with the tips I have learned over the years from using this tool so much. With my video I got you in as close as possible to really see what the process is so you can see someone else do it first before you attempt it so you can have a successful extraction plug after plug. I really hope this helps as many really shy away from this kind of stuff.
I usually use that every time I have to do 3v plugs.
They are considered 100k plugs, so the amount of time the plugs are in the heads doesn't help the 'corrosion weld' if you get my point. I tried the autolite plugs that claim to be the fix, and the truck DID NOT run right. That was a huge waste of money.
