5.4 issues Valve train/head noise
Lost
PA Chapter leader
3,288
central PA
Had this posted else where. Found a 06 F250 4x4 sc with 5.4 for $9000 100000 miles
Has noise rap in left bank . Other than head redo what else may I run into that will need replaced . I know possible push rod or cam .
The modulars have had ongoing issues with chain tensioners, valvetrain noise. If debris was caught in the oil passages, it will starve the head for oil. I think theres a restrictor in the oil line that commonly gets plugged. Cheap oil filters, extended oil change intervals are the main contributors.
Lost
PA Chapter leader
3,288
central PA
I knew I wasn't in kansas any more when started to research them .
Will wait till I get them Ford repair manual in mail to see.
Lost
PA Chapter leader
3,288
central PA
So If I get a set of heads and new chains May be good to go?
Lost
PA Chapter leader
3,288
central PA
Be kind of pricey, but yeah!
Considering truck just like it r on lot with same miles for $3-5000 more I'm ok on parts . I found whole 70000 mile motor for $1000
