5.4 cranking time
nobodyspecial
Fire in the hole...
5,756
366
ND
The 5.4 in our Expedition seems like it cranks longer than it should before it fires up. It has been like this since we got it, nothing has changed.
Just wanted to check with other 5.4 people and see if something is up.
Sent from my modded Galaxy.
Does it change when you let the fuel pumps reach pressure before actually cranking it?
Mine stars much quicker since I changed the God Forsaken spark plugs that break off the head.
If you can put a fuel pressure gauge on it, turn key on to build pressure, then when you shut off key, it should hold pressure for a couple of minutes. If not, regulator or fuel pump allowing pressure bleed off.
nobodyspecial
Fire in the hole...
5,756
366
ND
Thanks. Do you have more info on that? Any specific type of fuel pressure gauge? Where can I get one?
nobodyspecial
Fire in the hole...
5,756
366
ND
About the spark plugs, what year range had that problem?
