- 5
- 0
I want to take the entire 4wd out of my 97 Expedition and install it in my 03 King Ranch Supercrew 2wd. Other than alot of work will it fit. Any insight appreciated , yea I know it seems like a waste of a good Expedition.
Why don't you just buy a 4x4 truck?
Yeah, Chris is right about the gearing.
That KR probably has like 3.10 gears in the back, not great for 4x4.
Well I don't know about compatibility for those model vehicles but the nature of 4wd will require swapping the front axle, front driveshaft, the transfer case, 4wd electronic control module (if it's shift-on-the-fly), the dash switch or floor lever for the tcase. You'll also most likely need to wire your computer to accept inputs for the tcase, as well as the cluster to light up the indicators for the 4wd. There may already be harnesses for these things so rewiring may not be necessary.
Also you'll need to resize your rear driveshaft to account for the added tcase. Are the gear ratios the same between these two vehicles?
my 97 5.4 has 3.73 gears also not sure if the frames are the same 97 to 03 (understanding that the expy's are built off the F150 frame)
Different frame than the F150. Actually, Expy's and pickups share a lot less in components than folks think. This'd be the conversion from hell- much cheaper to just sell the PU and get something comparable in 4X4, IMO. Don't forget a lot of these components are computer-controlled in the pickup- NOTHING is simple on the later model trucks for mods.
