- 5
- 0
Lokin to put a 302 in my 90 ranger 4x4 got 302 out of 89 f150 2wd with 4 speed is there an adapter to mate trans to stock trans
fer case?
fer case?
Ok appriciate it. And im goin carb the motor is out of mercry capri. Will a fuel inj. Trans still work on a carbed motor and would it bolt rite to transfer case or would an adapter still be needed?
Just found a ford top loader 4 speed manual with 205 transfer case was bolted to a 351 m would that bolt up to my 302
no different bellhousings.. the 351M has the big block bellhousing.. (same as 460)
shouldve been more detailed on this part.. you need a 302, 351 WINDSOR, or 300 I6 trans..
