3 inch body lift REMOVAL
odogf150
YOUNG GUN
398
utah
ey i got a unusual question for everyone, has anyone taken off a body lift before?? i am planning to do so due to my truck being a lil high and me being only 5-8, but anyway if so, whats the affects and what will i need to do?
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
pull out the spacers, its possible you have a steering shaft extension as well...
When you put the bolts back to bolt the cab to the frame, get some new grade 8 bolts washers and nuts...
Should be relatively easy. If whoever put the BL on did it right, you may have some extended lines (brake and p/s) and linkages...but that shouldn't be a big deal. You may also need to re-relocate your radiator and bumpers. But all that is predicated on how involved the installer got with the BL.
Along with the new bolts and washers, it wouldn't hurt to spring for some polyurethane or other good rubber bushings ;)
