2010 mkt
Vince, can you please post the procedure for removing the drivers' side, drivers' door panel?
I need to replace the speaker.
Thanks!
Removal and Installation
Remove the front door trim panel reflector and remove the front door trim panel rear lower screw.
Remove the front door trim panel rear screw and bumper.
Remove the front door trim panel rear upper screw cap and remove the rear upper screw.
Remove the front inside door handle screw cover.
Remove the front inside door handle screw.
Remove the door trim panel center screw cover.
Remove the 2 door trim panel center screws.
Remove the 2 front door trim panel lower screws.
NOTE: The front of the door trim panel is shown with the locations of the door trim panel retainers indicated.
Remove the front door trim panel.
Pull the front door outward to release the retaining clips.
Disconnect the electrical connectors.
Disconnect the front door handle cable.
To install, reverse the removal procedure.
My experience with Lincoln's tell me that you'll be blue in the face before the retainer clips turn loose.
Awesome.
I might just take it to the dealer...they have always been good to us, I just figured this would be painless....:rofl::rofl::rofl::rofl:
