- 3
- 0
I have a friend I am trying to help run this down on. The light was on and we did the 100000 mile service plugs, coils, oil and filter, and because the light had the o2 sensor fault both of them, air filter, fuel filter. The battery was disconnected and then the light was off. It came back on and had the voltage low on the o2 sensor and had a rough idle. I replaced the cold air idle valve. That did not work either. I checked with a scan tool and the fuel trim would be all over the place when it would idle rough ( only when cold). Then I called a few shops and al 4 said it would be a programming issue one said they could do it adn the other three said to take to a dealer. I got the vehicle reprogrammed today and it was driven home app 100 miles. The light is back on. Not sure the code but most likely the same o2 sensor low voltage.
Any assitance would be greatly appreciated. Very frustrating.
