- 2
- 0
Hi, O know I'm new to the forum but don't usually work on newer Fords. I bought a 97 Ranger with the 2.3 with a known broken timing belt. I replaced the TB and water pump, only to find out the head was cracked(got very hot). I ordered a reman head and put it on. Head came with instructions to run engine at 1500 rpm for 3-5 minutes after startup. I ran it at 1500 rpm for 10 minutes after startup, but still had a little bit of lifter clatter at idle(sounded like a quiet diesel). So, I ran it for 15-20 miles, same clatter, smoothing out by about 2500rpm, but gets slightly louder when warm. I called the company I got the head from, they said probably a bad lifter, so I ordered two and have taken the valve cover off to replace them.
My question is: How do I isolate the bad one, and how do I replace it?. I bought the head assembled, so this is something I'm not sure of. Please help I need to fix this thing it's my only transportation right now. Sorry for the long post.
