1963 f100
19
Ok so it has only taken 4 years and I am still not finished but:
63 short bed with a 56 box
77 302 with a C4-Edelbrock, HEI, duals, Lokar floor shift
Lowered into the weeds by flipping the axles.
Needs transmission leaks fixed, lose the HEI for a pertronix unit (HEI bad, Pertronix good), pick the back up some (or get skinnier tires on the back), and on and on...
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Right side cowl molding (Dang Autocorrect the isn't)
C3TZ-8102328-A .. Moulding-Cowl Panel Side - Right/Left is the same / Obsolete
1963/64 F100/250 / No Ford dealer or obsolete parts vendor has any.
19
Found the molding on EBAY. Kinda crusty but cleaned up ok. Doesn't matter much though crusty is better than not.
19
Update: Kinda blew up the C4 so pulled the drive train and stuffed a TCI Street Fighter C4 in it. Had to pull the engine to get the trans out as I kinda left the original tranny support in when I built it (Sawzall fixed that problem). Added a Hughes 2k Stall converter and a bunch of braided line. Still need to put the engine back-Changed the pan to a bronco double hump looking pan from an 87 bronco. Also added the Pertronix distributor, under drive pulley, other useless bling. Will add new radiator and trans cooler, fuel and tranny gauges as well. Got all the parts, now I need the time.
