1 ton bump
15
If you're a bump purist this will likely make you angry. I bought this truck two years ago planning on just getting it running and having it as a mud truck. The truck when I bought it was a 69 f100 ranger body on a 73 250 hi boy chassis. It didn't run, had haphazard wiring full of residential wire nuts, wouldn't hold a charge, the front end was toast and the cooling system was full of crap.
After I got it sort of running I realized that I'd need to do a frame of rebuild if I wanted a decent running truck. I also hated the idea of turning a long bed on trails so I decided to shorten it by 18" and bob the rear.
No weld porn here but they'll hold
15
Now I'm in the boring parts gathering phase, I'm trying to be patient and do everything right the first time. I just cruise the interwebs looking for deals and grabbing them up when the budget allows it. I picked up this set of five HMMWV tires and wheels for around $200 and I had to grab em.
I bought a Dana 60 from an 05+ super duty to replace the busted hd44 up front.
I found the tank that is sitting in the back from a pick n pull for $15. It holds 33 gallons and came from a Mitsubishi semi.
The to do list includes
-Out boarding the leafs up front to fit the new 60
-changing the bolt pattern on the 60 from metric to standard
-convert the power assist steering to true power steering
-new wiring harness and pretty much all new charging system
-plate the frame where I made the cuts
-new shocks
-strip the motor and do a minor rebuild
- and a ton more that I haven't even realized yet.
Right now I'm deployed so I have ten months to save money, do research and order parts so hopefully when I get back I can finally make some real progress.
Nice....quite the project!
15
Thanks, I was scared as crap making the first cuts and remained nervous until we got the measurements after burning it all back in.
