05' explorer wheel bearing DIY needed
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
Yea, but having the instruction step by step right there is very nice, instead of having to wash your hands to go in and look at the next few instructions.
Wheel bearings is not a clean job...
IIRC the 05 'sploder has a unit bearing. Easy as pie.
1. Jack the vehicle up and put jack stands under it
2. Remove tire
3. remove caliper
4. remove disc
5. remove CV shaft retaining nut (If 4wd)
6. remove wheel speed sensor
7 remove 3 bolts on back of bearing assembly
8. remove bearing assembly.
Assembly is reverse of removal.
Hope this helps.
