05 E350 Chateau CD-6 Problem
63
7
Just wondering if there's a magic button, fuse or reset procedure for my non playing CD-6 unit.
The unit has no display when running.
If I put the headlights on, it displays the time correctly. I can reset the time with the Menu button.
The CD's will index, load and eject but will not play.
Can't play radio or CD under any conditions.
63
7
Thanks for the reply. Mine looks like yours. I have taken mine out of the dash (simple easy removal) to check for fuses etc. But no luck. So I bought a replacement for $25.😉
Beach66Bum
Top Poster Of Month
That works :D
Is your electrical harness all original? Both plugs are pushed in and seated well.
Was it working fine, then suddenly stop? Usually a CD that gets jammed causes the most common issue with these 6-disc units. Almost like you have a shorted out wire in the harness…..
