EFI/AOD update! Please help!
4,038
135
Trinity Tx
http://www.fordtruckfanatics.com/forum/showthread.php?t=7713
Hello again, I'm better with wrenches than electronics soooo....hopefully someone here can help an old dog with a new trick! I've got a 93'E150 conversion van thats worn&torn on the outside but has a good 351W and an AOD that I recently spent a small fortune rebuilding/bulletproofing. I want to slip this into my latest rescue,- a '70 F250 CS so that I can get my mileage/money out of the 351/AOD while I go thru the FE. I have no intentions of any permanent mods to my amazingly original,unmolested camper special. What I need is info on what I need to strip out of the van to support the EFI and the AOD in the old Ford. Since the rear-end scattered in the van, it becomes a donor for the truck.QUOTE]
He has a AOD E.
F150
easy
512
10
upstate NY
You'll need the ECU,harness,some type of fabricated fuel system, parts of the dashboard(circuits for sensor loops and such).
Some may suggest an intake switch to a carborator.....
havi
third member
FWIW, the 351W won't just drop into an FE equipped truck. The frame stands are completely different.
