Just finished my 130amp alt swap
663
So as the title says--- I just finished replacing my 95amp alternator with a 130amp alternator from a Taurus.
It's been kind of a long project because I had to gather parts from a few different places and then run back and forth between Davis and my mom's place to use the tools up here at her house (impact gun, bearing puller, etc).
I ended up getting the 130amp out of a Taurus. Andy and I went to the junkyard and I frankenstein'd about 3 alternators together to get 1 really new looking alternator (inside and out). I even found a Motorcraft voltage regular that was just about BRAND new!! ($95 part at the dealer). Walked out with the new-ish alternator and new-ish voltage regulator for $25 :rofl2:
Then I ordered a thicker charge cable and bearings from RJMInjectiontech.com, same guy that runs for fordfuelinjection.com. That was a life saver because NONE of the parts houses sell these danged bearings.
Replaced the bearings but the case was still wrong. My truck had a side mount alternator and the Taurus has a pivot mount alternator.
Turns out the PSD also has a side mount alternator so my brother gave me his old one (non-working unit) and I swapped the guts of the Taurus alternator into his PSD case :D
Just finished installing everything and WHAT A DIFFERENCE! The reason I started this project was because the Taurus fan was pulling major power and my alternator couldn't keep up at an idle, even on the low speed! Now I can turn the fan on high speed, while idling, and the gauge dips a bit then pops right back up to normal :nana: Sooo worth it.
Cost of project:
$25 --> alternator + voltage regulator
$40 --> 2AWG charge cable + (2x) 175amp Mega Fuses + Fuse holder
http://rjminjectiontech.com/images/alt-cable.jpg
$10 --> Front and rear bearings for 3G alternator
http://rjminjectiontech.com/images/3Gbearing.jpg
If anyone is considering this swap, I highly recommend RJM Injection for any parts that you may need, especially bearings. They're OEM bearings (best I can tell) and the service was fantastic. The quality of the charge cable is also very impressive, looks exactly like the picture.
Good to hear Chris, glad to hear when projects turn out good. :)
radialarm
Clown of Death!
Oh a special thanks to Robert (radialarm) for giving me a few pointers along the way YelloThumbUp
No problem Bro. anytime.
You got plenty O juice now huh.
:beer:
Mr. Stroker
CASE IH
3,121
67
Michigan
Thats sweet skan.
Ive been wanting to do this as well, hate seeing the alt guage dip way down while my trucks at an idle with the off road lights are on.
What other vehicles have a side mount alt thats a 130 amp?
663
PSD, and I THINK the older explorers and vans have them too, but I've not confirmed. They're definitely side mount, but I'm not sure if they're 130amp. It can be confirmed by comparing case diameter. The 130amp is larger than the 95amp.
Mr. Stroker
CASE IH
3,121
67
Michigan
Maby il take a run to the junk yard next weekend to confirm and maby buy one for my own. Or i can call the parts store tomorrow and see what they got.
radialarm
Clown of Death!
My gallery has a lot of info. on these alternators, just read the captions and descriptions.
