can anyone tell me how to get this off? I didn't see any apparent screws or anything to undo.
I can't remember how similar that tranny is to mine (they share a name, and a reputation), but the Ranger ones are famous for leaking out of some rubber plugs behind the shifter. They dry out, shrink, and leak. You can either silicon 'em back in place, replace them with more of the same (but why?) or replace them with metal plugs.
Not sure how you'd get to them on that truck, or even if this applies to the full-size M5OD, though.
I remember lots of guys bitching about those plugs going south on the M5R2 (real name for your transmission Tom). The M5R1 is the Mazda trans in the ranger--- M5R2 is the bigger one in the full size trucks.well since this thread went pretty much nowhere, i'll ask about what i assume is under there.
i've got an M5OD and it's got a bit of a drip - i've noticed a little bit of fluid running down the side. it's not coming out of a drain/fill plug and it doesn't really look like there's anywhere else but where the stick goes in the top for it to leak.
looking from the bottom, it looks like there's plate up there on top that could be leaking. how likely is that? is there just a gasket up there to replace? i just changed the tranny fluid the other day and got the outside of it all cleaned up and i've got a drip or two coming down the sides
...but the Ranger ones are famous for leaking out of some rubber plugs behind the shifter
yea, it's really cheap. everyone i work with takes their cars there. it's a 1-guy, 1-bay operation that keeps costs really low. really nice guy.Holy crap! Only $30/hr?! Round here the going rate is upwards of $80-90! Good luck with that. Make sure it's a semi-reputable shop so you don't get a botch job.
