89frankenford
Grabber Green Consultant
ok i am HOPEFULLY putting the rear axle into the truck this weekend
i have the old carrier out of the axle right now and currently in my basement on my make shift bench (steel chair haha
) ive got new clutches, center spring, and center pin.
the question i have is regarding the clutch kit. how should i install the clutches and steel plates? they are currently installed as follows going from the outside to the inside(outer edge of the gear)(left to right in this case)
Steel, Clutch, Steel, Steel, Clutch, Steel, Steel, Clutch
is this the proper way to have it set up? or is there a better way to do it? thanks a lot
) ive got new clutches, center spring, and center pin. the question i have is regarding the clutch kit. how should i install the clutches and steel plates? they are currently installed as follows going from the outside to the inside(outer edge of the gear)(left to right in this case)
