2011 Ford Superduty Unveiled at Texas State Fair
89frankenford
Grabber Green Consultant
4,547
147
NH
Jalopnik revealed the 2011 Ford Super Duty.
i personally really like it a lot. i LOVE the way the gauges are set up
2011 Ford Super Duty Unveled at the Texas State Fair
For 2011, Super Duty features both an all-new diesel and gasoline engine that are mated to a new transmission. The new diesel, the 6.7-liter Power Stroke V-8 turbocharged diesel engine, was designed, engineered and built by a Ford team dedicated solely to delivering this class-leading diesel engine to the next-generation Super Duty to enable continued best-in-class towing and payload.
Benefits of the new 6.7-liter Power Stroke diesel engine:
· First use of a compacted graphite iron (CGI) engine block in a Super Duty-class vehicle in North America; CGI is stronger than cast iron, and Ford successfully has used the material in engine blocks in products around the world. The block structure was optimized for reduced weight and maximum strength to meet the demands of higher torque, more horsepower and better fuel economy.
· Unique inboard exhaust and outboard intake architecture, an automotive-industry first for a modern production diesel, reduces overall exhaust system volume, which leads to better throttle response; a reduced exhaust system surface area minimizes heat transfer to the engine compartment and improves NVH (noise, vibration and harshness).
· The single-sequential turbocharger features an industry-first double-sided compressor wheel mounted on a single shaft. The unit is uniquely center-mounted on a pedestal low in the back of the valley for improved NVH. The design allows the single unit to deliver the advantages of a twin-turbocharger system in a smaller, more efficient package, combining the benefits of a small turbocharger (faster response) and a large turbocharger (ability to compress and force more air into the engine for more power) in one unit.
· The high-pressure fuel system injects fuel at more than 29,000 psi. The system delivers up to five injection events per cylinder per cycle using eight-hole piezo injectors to spray fuel into the piston bowl. The direct-injection system is calibrated and phased for optimum power, fuel efficiency and NVH.
· Aluminum cylinder heads for reduced weight; the mid-deck construction with dual water jackets provides increased strength and optimal cooling; six-head bolts, instead of four as found on other engines, help improve sealing and maintain cylinder integrity even with the higher firing pressures.
· Compatible up to B20 fuel, allowing greener fueling options of up to 20 percent biodiesel and 80 percent petroleum diesel.
"Developing the new 6.7-liter Power Stroke V-8 turbocharged diesel engine was an awesome endeavor," said Adam Gryglak, lead 6.7-liter diesel engineering manager. "After all the engineering and testing, we're confident this engine will ensure the new Super Duty continues its leadership in capability, reliability and productivity."
The engine and aftertreatment system for the 6.7-liter Power Stroke V-8 turbocharged diesel powertrain ably meets the new, more stringent 2010 federal emissions requirements for nitrogen oxides (NOx), which have to be lowered by approximately 80 percent.
New gasoline engine delivers more torque, horsepower than outgoing model
Ford tapped into a bit of its proud racing heritage to create the new 6.2-liter V-8 gasoline engine, which uses big-bore architecture to produce horsepower and better fuel economy. The V-8's large bore (102 mm) allows for larger intake and exhaust valves for improved engine breathing, and the short stroke (95 mm) allows higher engine speed for increased horsepower.
Benefits of the new 6.2-liter V-8 gasoline engine include:
· SOHC valvetrain with roller-rocker shafts: The single overhead camshaft (SOHC) per cylinder head design results in a stiff valvetrain that allows optimized camshaft lift profiles and results in great low-speed torque. The roller-rocker shafts allow valve angles to be splayed, resulting in optimized intake and exhaust port layout for better breathing.
· Dual-equal variable cam timing: Intake and exhaust valve opening and closing events are phased at the same time to optimize fuel economy and performance throughout the engine speed range and throttle positions.
· Two spark plugs per cylinder: Due to the large bore size, two spark plugs per cylinder are used to more efficiently burn the fuel-air mixture in the combustion chamber, enabling better fuel economy and increased engine torque. The twin plugs also help the engine maintain a smooth, stable idle.
· Dual knock sensors: A knock sensor on each bank of cylinders of the V-8 engine allows the spark timing of each of the cylinders to be individually optimized real time, throughout the engine speed range. The engine learns the optimum timing via an adaptive algorithm.
· Better engine crankcase "breathing" and efficiency: Significant development work and computer-aided engineering optimized the cylinder block for more efficient airflow in the crankcase as the pistons move up and down in the bores, resulting in improved torque at higher engine speeds. Piston-cooling jets squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions. The cooling jets also allow for a higher compression ratio for better engine efficiency and faster engine oil warm-up on cold starts, also improving fuel economy.
Dang, you two are on the ball...identical stories at the same time:
http://www.fordtruckfanatics.com/forum/showthread.php?t=15651
But yeah...I think the truck is awesome...I just can't stand the grille and headlights...looks kinda cheap and tacky like a dodge. It's almost like Ford ran outta money developing the 6.7 and decided to make it look as cartoony as possible.
surewhynot
Rep whores make me sick
13,843
821
Florida
If the new engine goes through with no bugs, Ford stands to set the new benchmark, I think.
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
Sent: Thursday, September 24, 2009 12:30 PM
To: U.S. Team
Subject: Resend: Reveal of the all-new 2011 Ford Super Duty
[FONT=Calibri, Verdana, Helvetica, Arial]
1_multipart
This morning, we will take another step forward in solidifying Ford’s truck leadership as we unveil the all-new 2011 Ford Super Duty to media at the State Fair of Texas in Dallas. The press event can be viewed beginning at 2 p.m. EDT at www.thefordstory.com.
Mark Fields, President of the Americas, Chris Brewer, Super Duty Chief Nameplate Engineer, and Adam Gryglak, Diesel Chief Engineer will be on hand in Dallas to reveal the all-new truck to members of the press and public, along with other guests.
The all-new 2011 Ford Super Duty – with a new 6.7-L Power Stroke V-8 turbocharged diesel engine, a new 6.2-liter V-8 gas engine and the new 6R140 heavy-duty TorqShift six-speed automatic transmission – will deliver significantly higher torque and horsepower, class-leading fuel economy and best-in-class towing and payload capability.
Ford F-Series has been the best-selling line of trucks in the U.S. for 32 straight years. To learn more about the 2011 Super Duty and Ford’s truck leadership, press materials and a variety of technology facts sheets are available to download on www.at.ford.com.
For additional information that can be shared with friends and family – including Super Duty product information, images and links to Webisodes that feature Mike Rowe and our engineers that designed and built these new powertrains – visit www.fordvehicles.com/2011superduty.
Please be sure to join us in celebrating the launch of this great new truck.
[/FONT]
blackhat620
You Had to be There
1,687
150
Arizona
