***Wanted/Selling dent/bump parts***
I might be interested in one of these beds you speak of Ben! Let me know some info on them
Alright...will do. Dunno if you're a member, but they were posted over on NC4x4. Then there was a red '77 shortbed at Galloway's, but Lester said there was a potential buyer for the whole truck, dunno how that went though.
Inside the canopy ...Just make it up yourself with white 2 strand wire.
You can buy (2 prong male/female) Ford connectors off the shelf.
Outside:
The Power to the canopy gets power from the solenoid runs under the cab to just behind cab then up to the corner.
Would you like pics of original ?
I need a front bumper for my '77...anyone got one?
I got one...but shipping would be killer. Try hopping on JBG's website, they have a classifieds section and they're in Michigan.
I have one from a 75
I'm looking for the coffee can vacuum reservoir that mounts on the inner fender. The one I need to replace is the longer (10"ish) one. If you have something, let me know.
The metal one I had leaked on me and after soldering it up it leaked again.
I replaced it with a plastic ball. :)
It twernt easy but I managed to hang it from the 75's firewall/cowl seam lip.
I like to use wet-contact-cement as a "hose lube" when installing vacuum
hoses. YMMV on that one. ;)
I've been using fuel-hose for all my vacuum hoses and recently started using
some soft aluminum tubing for the '91 Bronco too.
3/16" fuel hose isn't the easiest stuff to find but it can be found. ;)
Alvin in AZ
IMO...that's a bit steep for that 44...and I think the 70 is a seriously underrated/under talked about axle. I'd rather have that 70 than a 10.25.
Took a picture of the vacuum-ball hanging from the seam-lip...
http://www.panix.com/~alvinj/file12/vacuum.jpg
Ford had put the original vacuum-can in front of the module.
Intentional or not, it blocked radiant heat from the module. :)
I wanted to move the vacuum-can back out of my way, so
I came up with this to protect my Blue-Streak module...
http://www.panix.com/~alvinj/file12/module.jpg
That's not as easy to do as it looks, BTW. ;)
Much later found the original-vacuum-can leaking again (after
soldering it up once) so went with the ball. Being smaller it
could be mounted even farther out of my way. :)
Alvin in AZ
I am looking for:
The "Ranger XLT" bedside emblems, I thing they ran from 73-76 (or 77).
The lower trim on the front fenders for 73-76 (or 77).
Please PM me if you have either of these for sale.
Thanks
I've got a few dentside parts I'd like to sell reasonably.
all parts are driver or good condition,not new
Explorer bedside emblems $10 7/10 condition
F250 Custom cowl emblems 77-79 $10 7/10 condition(inside of emblem will need resprayed black)
Washer fluid jug, good condition $15
Camper special emblems, (good condition, but will need inside of emblem sprayed red to look real good) $10
PM me if interested, thank you
I am looking for:
Thanks
http://cgi.ebay.com/ebaymotors/Ford...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Here's these, they would look good with the inside black resprayed, chrome looked pretty good. But the studs looked like they may have been butchered, from the quick glance that I took of them.
Also..I'm wondering anyone has or knows where to buy dome light lens' that say "Ford" on them. My lens is starting to get brittle and I'd like to find a unique lens like stated.
or if any are made?
Thanks for your help
