- 134
- 0
Also bith heater core hoses are leaking at the connection points on heater core where the hose goes over the metal tubes. Ill have to get heater hose in future
Sent from my SM-N975U using Tapatalk
.Idk if u can see this or not. But this sounds harder than it should be
That is a seal. One piece gasket takes care of it, or if you go cork the 2 ends are rubber. Fit in the slot. You put form a gasket in the 4 corners to create an additional seal. Just a dab. It spreads when the gasket smashes downThat leak is right at the "U" of the oil pan by the transmission
