flareside_thunder
Florida Chapter member
- 7,812
- 246
Yup 38 dollars for the solenoid pack......I was under the same assumption with the AODE-W as well.
There is really no such thing as the AODE-W. I guess u can technically call it that, considering the 4R70W is a revised version of the AODE with wide ratio gearing.
and i've seen a few 302 powered 2wd trucks with the AODE, pretty rare but its like the F-150s with a 302/E4OD combo...rare but they do exsist.
1994 Bronco/Econoline/F-Series Contents/Index
Group 07: TRANSMISSION
Section 07-01A: Transmission, Automatic, E4OD
Section 07-01B: Transmission, Automatic, C6
Section 07-01C: Transmission, Automatic — 4R70W (AODE-W)
Section 07-03A: Transmission, Manual, M5OD
Section 07-03B: Transmission, Model S5-42 ZF
Section 07-05: Shift Controls, Automatic Transmission
Section 07-07: Transfer Case, 4x4 System, Service
Section 07-07A: Transfer Case, Electronic Shift
Section 07-07B: Transfer Case, Manual
uhm you do realize that Nextras works at a dealership. so im fairly certain he knows.
