Trnsmission Woes....
973
11
good to know, ill be replacing mine soon.. finally i can get my FORD back on the road, enough with the S10 haha
optikalillushun
Coal Cracker
70
3
There is really no such thing as the AODE-W. I guess u can technically call it that, considering the 4R70W is a revised version of the AODE with wide ratio gearing.
and i've seen a few 302 powered 2wd trucks with the AODE, pretty rare but its like the F-150s with a 302/E4OD combo...rare but they do exsist.
384
uhm you do realize that Nextras works at a dealership. so im fairly certain he knows.
heres a cut and paste from the 94 workshop manual
1994 Bronco/Econoline/F-Series Contents/Index
Group 07: TRANSMISSION
Section 07-01A: Transmission, Automatic, E4OD
Section 07-01B: Transmission, Automatic, C6
Section 07-01C: Transmission, Automatic — 4R70W (AODE-W)
Section 07-03A: Transmission, Manual, M5OD
Section 07-03B: Transmission, Model S5-42 ZF
Section 07-05: Shift Controls, Automatic Transmission
Section 07-07: Transfer Case, 4x4 System, Service
Section 07-07A: Transfer Case, Electronic Shift
Section 07-07B: Transfer Case, Manual
384
and the man himself steps in and shows it.
95 manual
1995 Bronco/F-Series Contents/Index
Section 07-01C: Transmission, Automatic, 4R70W
Section 07-02: Transmission, Automatic, Cooling
Section 07-05: Transmission, Automatic, External Controls
Section 07-07B: Transfer Case, Manual Shift
Section 07-14A: Transmission Range (TR) Sensor
Section 07-14B: Park/Neutral Position (PNP) Switch
Section 07-14C: Clutch Pedal Position (CPP) Switch
973
11
blacksnapon beat me to it..
yes i do work at a dealership, look at my Sig.. York Ford Inc. Saugus MA lol
me and blacksnapon have access to the same "database" if you will
if im not mistaken, heres the order:
AODE-W-->4R70W
E4OD--> 4R100
I hear alot if people say the 302/E4OD combo is rare, but all the people i know around me with this gen F150 have 302/E4OD combo..
flareside_thunder
7,812
246
Wow, didn't realize this thread was this old...anyways. I replaced the MLPS previously when all this started and assumed it had fixed the issue...wrong. So, I'm still fighting this and not happy with the clarification process thus far lol. I have no problem buying a new TC(I can get a higher stall one) or a solenoid pack...it's the new transmission that has me a little sweaty.
