oOOoOooOOoh Doc.......
You know you want this under your hood
I want a three-deuce setup on my 4.6L or even a dual quad. That would be sick...
I'd be willing to bet that the ignition system on your truck (Doc) is more efficient and burns fuel more efficiently, giving more power. I can't imagine that they would have spent all the time and money (clearly your system is a lot harder to manufacture) to design and implement that system when going back to a carb would have been a safer bet. That ignition system you've got is pretty advanced.
Just speculation of course.
Being that your engine is almost entirely computer controlled, I'd be more inclined to believe that a computer flash would be MORE of a step in the right direction. My brother's 7.3L can pick up something like 75hp just from a different program on his computer-- add bigger injectors and it puts him up at something like 150hp over stock. It's rigoddamndiculous.Oh I'm sure it is fine, but you know my theory....If it ain't broke, fix it till it is! LOL
They are going on about the upper RPM's and I have noticed mine plateauing(sp?) at the higher RPM's.
I am curious to see if it is worth it to do that then get the computer flashed or just try the computer first and go from there. We need more research.
Yep, I think the flash would be a good start. Even if I decide to go with it later down the road, I should be able to adjust the flash. but seriously, would it not be cool to look under your hood and say "yep, its a Holley!" HAHAHA
