flareside_thunder
- 7,812
- 246
Are they peanut butter cookies?I like peanut butter cookies.....
JR
JR
I said that the new kits come with LARGER water pump and altenator pulleys as well as a SMALLER crank pulley...thus providing the ample output needed to sufficiently produce via the LARGER pulleys...so how do those accessories turn slower?Indulge me PLEASE!I am begging you to show me the light and bring my IDIOCY to the surface in one of my previous posts......
JR
Bob, try to stay with me here...first off.you are an ignorant ignorant human being.....secondly.......a larger pulley will act as a reduction pulley.....think of it this way.....if you have 4.11 gears with 35's your tires will turn pretty good...if you take those 35's off an put 215 75 15's on it you'll burn the tread off......the larger pulleys will turn the accessories more in one turn than they would with smaller pulleys making the size differences VOID!This is a moot point arguing this to someone who doesn't comprehend well and LISTEN ferget it you're right I'm wrong whatever.
JR
the smaller pulley, gear w/e will spin faster while the big gear/pully/ w/e will spin slower...
go get a 10 speed mt bike. Flip it over and check it out...i dont see any reason to continue the discussion pass this.
Ok I tried to drop it u brought it back up.......I have a smaller crank pulley on my truck..the alt and water pump pulleys are stock size....so how is it...that my voltmeter reads right on the OUTSIDE EDGE on the N on Normal?if you're theory is right it'd be on the other end of the gauge right?...but yet....when you put BIGGER alt and WP pulleys on it the gauges read as if nothing had been changed??????
JR
Ok genius I tried to drop it u brought it back up.......I have a smaller crank pulley on my truck..the alt and water pump pulleys are stock size....so how is it...that my voltmeter reads right on the OUTSIDE EDGE on the N on Normal?if you're theory is right it'd be on the other end of the gauge right?...but yet....when you put BIGGER alt and WP pulleys on it the gauges read as if nothing had been changed??????
JR
