How many miles on this engine ?
If you have two gas tanks, there is a 6" piece of rubber hose behind the midship tank that can only be accessed by removing the midship tank. I didn't have any fuel delivery problems, but the piece of rubber hose was badly weatherchecked. This was on a '78 with a plastic midship tank. I don't if other years are similar.
Might have to jet that carb or play around with the springs and metering rods to get it right. Get a Edelbrock jet and metering rod kit from a parts store and then just look in the manual that came with the carb or go on to edelbrocks website to figure out what rods, jets and springs you can try. Ive had some minor hiccups like that with my edelbrock and it was usually just needed a little tunin to get it right.
I'm not saying you are wrong, but it was fine for like 5 months, so I don't see how those could get messed up. But I'm sure you would know better than I would, I am fairly new at this, this is my first vehicle.
Have you pulled the fuel line off the carburetor and put a fuel pressure gauge into the fuel line and then crank the engine to see what the fuel pressure is like ?? Anything less than 5 psi would be a concern to me. Good luck. 75hiboy
I doubt that really was the problem considering what you worded the symptoms.
But I have to ask, was it the #1 plug ?
Next time run the engine at night when it's dark.It makes it much easier to see any problems.
