- 132
- 0
I am having a problem with my truck when going up a hill, it's hard to describe but its kind of like the fuel flow being cut off for just a split second or like the engine spitting, and if I give it more gas it does it more and then starts to bog down the engine. Does anybody know what might cause this? I thought maybe it was probably the fuel filter so I replaced that, but it didn't help. Then I thought maybe it was because it was only running at 170 degrees and not burning the fuel correctly, so I put in a warmer thermostat but that didn't help either. iI has a new Edelbrock carburetor I put in this spring and it is a 351m. Does anyone know what might cause this? accelerator pump maybe? It was fine for months after I put in the carburetor but started doing this after I put in a new radiator in the fall which is why I thought it was the temp, but it was fine for a month or so after that. Thanks
