primetime
sawmill slave
As for 600 or 650, Holley vacuum secondary carbs are usually rated at 600 cfm except for the Street/Truck Avenger carbs which have a 670 cfm rating, Holley mechanical secondary (double pumper) carbs usually carry a 650 cfm rating. Edelbrocks are rated at 650 cfm with vacuum secondaries. Does it matter if you have a 600 Holley or a 650 Edelbrock? No. The performance difference is negligable if at all. It basically boils down to preference and what you are willing to pay. Holleys are very tunable, but that can lead to problems if you buy a used one from somebody who modified it without knowing what they are doing.
Holley vacuum secondary carbs do not REQUIRE tuning, but they CAN be. On a Holley it is a matter of changing the spring in the pod on the side of the carb. Holley Street/Truck avenger carbs have an adjustment knob which allows for tuning the secondaries for a little better fuel economy, or more horsepower without going to far and hurting things. Edelbrock also has carbs that allow the same thing. Keep in mind that putting too light of a spring in the secondaries will open them too soon causing the engine to bog because The engine isn`t ready for the extra air and fuel.
Realistically, whichever you choose be it a 600 Holley or a 650 Edelbrock is going to be very close to what you need right out of the box. Set your idle speed and idle mixture and you`ll be just fine.
