TexasNomad
FTFS Designated DRINKER!
I guess I could go with this...
http://www.paperformance.com/scripts/prodView.asp?idproduct=88
awesome thanks Lee..
So I are all maxi fuses the same?
Well i guess my trucks been messed with over the years, because my battery cable was bolted on to the solenoid, so I need to run two cables one from the bat to the solenoid and one from the alternator to the battery..
All "Maxi" fuses are physically the same size, but only go to a maximum of 100A. You need a "Mega" fuse & holder as these are rated up to 250ASo I are all maxi fuses the same?
OK, snapped a pic.
You're wired correctly, but you need to get a Maxi fuse in there. If that big 3g ever faulters and goes full field a fire won't be far behind!
Here's what mine looks like. (complete with Optima battery, red top though, not yellow)
Harness? The one that eliminated the voltage regulator? That would be this http://pa-performance.com/Scripts/prodView.asp?idproduct=75.
