I just picked up my 2001 F150 XTR last week. I have found few thing I have to figure out, here they are
1. Air Bag light is on - it flashes 2 then 7 until it stays on constant, the dash switch for the the passenger air bag is also not on either. What could this be?
2. The temp dial for hot and cold does not change unless you shut the unit off the change temp settings and turn back on.
I also do not have the owners manual, I have the case for it but it only has the original warranty stuff in there. Does anyone here have a 2001 F150 owners manual or at least can you post up what fuses do what forthe fuse panels.
I have also installed HID's to it but have found that this truck uses the low beams as the DRL's so it causes a problem with them. I would like to know where this unit is located and the wiring codes for it. Both my Taurus SHO and my Cougar used the high beams for the DRL's and no problems at all with the HID's.
I look forward to this great site and thanks in advance for all your help and advise.
