Big Jim F150
73-79 Ford Trucks Rock
Try replacing your door jamb switches for your dome light, I had to replace the switches in mine, they both were bad, more than likely you have the original switches in there, replacing the both switches should solve your dome light problem, that's where I had found my problem, and also check for loose connections as well, my switches went bad on the drivers side first, then later on the passenger side later, so I knew it was switches in my case, hopefully this is helpful to you. You can get the switches at any auto parts store.
