- Moderator
- #41
I think I would however diagnose the po340 first. Look at the sensor and wires on the passenger side, top front of the motor for damage or chafing of the wires.This is rapidly turning from a problem to a nightmare
Anyways she ran it by her mechanics and said they would start by looking at the solenoids? That the same as sensors Vince?.
I feel they saw the TSB about aftermarket oil filters, said OH that's the problem and didn't do a complete diagnosis of it, for whatever the reasons are.
I am pissed at myself for not going with my gut and taking it somewhere else to begin with! DANG that pisses me off more then anything.
They said when they drained the old oil it came out brown and gritty...
They said when they drained the old oil it came out brown and gritty....
Wow.... It's pretty sad that there ARE people out there that fall for these scamsSo interesting phone call with the service manager.
Said he wanted my written permission for a complete engine tear down and rebuild. When I told him I did not have confidence in his shop after what they had done he told me I should take my business elsewhere.
And that I will.
Amazing lack of customer service. No sorry you feel that way, no we would like to try and make it better, no nothing just "you should take your business elsewhere.
Geeze Aaron, my tech of choice posts pictures of the whole procedure right here on FTF!!!
Sounds like they are in the right area. Question will be how far they go for a precise diagnosis. They should be able to pinpoint to a specific cylinder (if a bad hla or camshaft lobe). If the issue is localized to one side, you go to a phaser or tensioner. Both sides, I would think oil pressure or bottom gear or crankshaft.Punk!
Having not seen the truck Vince what would your first guess be for the actual cause?
That's good news right there Aaron. Glad to hear that these actually know what they're doing and SEEM to be pretty honest.Said she had every indication based on what she saw and has been told that this will be a warranty issue.
No, because it also has a noise. If the sensor was contacting the wheel, it would , but it would conceivably set dtcs leading in that direction.Vince, could it also be the Crank Position Sensor in this case?
Yeah, the oil pressure sounds right. Just in case, stay with the motorcraft filters. That way, there wont be any cause for arguement.She did say there is noise from both sides.
