Ford F-250 Axle question
I have a 92 ford f-250 with a 5 speed manual and a 5.0L engine, it looks like it has a 10.25 rear end but it is not a full floating rear. What is it and what kind of weight can it carry.
Thanks in advance,
Denis
5.0L? That's a pretty rare engine to have in a 3/4 ton. If you're sure it's not s full floater then are you sure it's not a rebadged F150? It should have a 10.25. Does it have the big hubs sticking through the centers of the rear wheels? (could be covered by a center cap). No hubs = no full floater.
wizzard351
ride'n on 35's
2,145
120
wi
dumb ? but how many lugnuts? if its 5 then id have to go with skan's idea it being a rebadged halfton. its not that uncomon for folks to rebadge them.
Lost
PA Chapter leader
3,288
central PA
Yes they had 302 and 5 spd in them In 93 94 it was hard to find 351 at local dealer for some reason. I had a 300-6 in a 92 350 . Every area dealer ordered different stuff.
The rear is a light duty rear no hubs. . Pay load ??? Usually saw them on 3/4 vans here .
So if I'm understanding correctly-- the 3/4 ton trucks with a 5.0L have an 8.8" rear end? Wouldn't that just make it a half ton? [confused]
Thanks in advance,
Denis
I have seen these before. it is a 10.25 semi floating as someone else said here. From the shop manual, the axle is rated at 5,300 where as the full floater is 6,250.
wizzard351
ride'n on 35's
2,145
120
wi
oh ok i see what yall's talkin about, years ago i had a lt duty 250 with a non floatin D60. i thought ford did away with that kinda stuff
