I'm gonna see if I can get my hands on a junkyard ICM that is the same as mine. I have a feeling that if I buy one and it doesnt work then they'll tell me I can't return it cuz I already plugged it in...
Somewhere around 115-120k.
Well I suppose I could refer to my fuel logs and give you a number that is accurate to 150 miles (generally drive 150 miles on a tank).I'm gonna be honest... for somebody who cares SO much about his truck, I figured you kept better track of it...
Heck, I can tell you within about 5k mileage on most of my friends cars, much less my own!
iPhone ain't puttin' out any weird signals that other 3G cell phones wouldn't be puttin' out. So put that in your pipe and smoke itI can't imagine interference from the radio is your issue, but if your Cobra is like my Uniden, you can unplug the power wire from the back of the radio pretty easily. It sure won't cause any issues when it's not plugged in...
*I'm gonna laugh my rear off if the problem is interference from your iPhone. Just throwin' that out there...
No not if is not powered up.Bill you think my CB radio could be causing the problem even if it's not powered on?
Replaced just the PIP sensor. I don't know exactly what the tolerances are but when the dist is mounted in the truck and I try to wiggle the shaft I can't make it budge at all.No not if is not powered up.
Without reading the whole post, did you just replace the PIP sensor or the whole distributor?
The bushings may be out of the distributor.
If you just miss one PIP then you will get that code.
You may have distributor wobble.
