mrxlh
Oilfield Trash
Matt double check the wires, 18436572 is the firing order. Standard blue streak ignition components are what you should be using. A multimeter can tell you if you have a wire that is bad.
The easiest way to pinpoint it is pull 1 wire at a time while it is running. Which ever one doesn't make a difference in how it runs is the culprit.
