The valve usually comes with a new gasket. At least the ones I've installed.
I sprayed carb cleaner in it. It still looks dirty.
Does the metal rod inside have to move up and down?
I am assuming when the coil is energized, it field is pulling up on the shaft opening something?
Is my coil measurement shown in previous post in the range?
Is there a way to test this and make sure the moving part(s) are actually moving?
I found a replacement valve but no gasket. I am thinking I can make my own.
What material is recommended?
Sorry for all of the questions but I just want to get this right.
I changed out the aic and it seemed to help. Still not good enough. This morning I changed out the throttle position sensor. This really seemed to help much better with idle. Now I have an issue when I punch the gas, truck pits and putters. Engine light comes on and tack goes down to about 1k, I let up on the gas and all seems ok again, engine light goes out. Punch it again and it pits and putters same way.
Could I have installed the throttle position sensor incorrectly?
Is it something else now?
I didn't have a problem with truck spitting and sputtering before I installed the throttle postion sensor. It never really took off when I punched it, but did downshift and not sputter. Am I supposed to do something else after installing it?
For the injector cleaner, I'm hearing Seafoam is a good one for my old truck. I've never heard of it. What do you say?
Also, do you have any codes?
