bottom bolt oil supply tube for turbo
Jun 22, 2012 Moderator #41 blacksnaponModeratorStaff member9,461301 waynesville,mo. bottom bolt oil supply tube for turbo
Jun 22, 2012 Moderator #42 blacksnaponModeratorStaff member9,461301 waynesville,mo. 4 bolts bottom of fuel/turbo cooler
Jun 22, 2012 Moderator #43 blacksnaponModeratorStaff member9,461301 waynesville,mo. turbo actuator connector
Jun 22, 2012 Moderator #44 blacksnaponModeratorStaff member9,461301 waynesville,mo. 5 bolts turbo heat shield
Jun 22, 2012 Moderator #45 blacksnaponModeratorStaff member9,461301 waynesville,mo. fuel lines on fuel cooler
Jun 22, 2012 Moderator #46 blacksnaponModeratorStaff member9,461301 waynesville,mo. 2 turbo hold down bolts, remove turbo Careful with the oil drain tubes, driver side is easy to break/bend out of shape. Last edited: Jul 26, 2012
Jun 22, 2012 Moderator #47 blacksnaponModeratorStaff member9,461301 waynesville,mo. glow plug module heat shield
Jun 22, 2012 Moderator #48 blacksnaponModeratorStaff member9,461301 waynesville,mo. heat shields over high pressure fuel pump
Jun 22, 2012 Moderator #49 blacksnaponModeratorStaff member9,461301 waynesville,mo. bolts for the 2 fuel lines rear of cyl heads
Jun 22, 2012 Moderator #50 blacksnaponModeratorStaff member9,461301 waynesville,mo. nut on check valve (fuel return)
Jun 22, 2012 Moderator #51 blacksnaponModeratorStaff member9,461301 waynesville,mo. connector for high pressure fuel pump
Jun 22, 2012 Moderator #52 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove fuel lines (high pressure fuel pump)
Jun 22, 2012 Moderator #53 blacksnaponModeratorStaff member9,461301 waynesville,mo. 2 nuts on fuel line
Jun 22, 2012 Moderator #54 blacksnaponModeratorStaff member9,461301 waynesville,mo. cooling fan connector
Jun 22, 2012 Moderator #55 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove fan and stator Last edited: Jun 22, 2012
Jun 22, 2012 Moderator #56 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove serpentine belt Last edited: Jun 23, 2012
Jun 22, 2012 Moderator #57 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove ac belt Last edited: Jun 23, 2012
Jun 22, 2012 Moderator #58 blacksnaponModeratorStaff member9,461301 waynesville,mo. remove retainer nut for ps lines
Jun 22, 2012 Moderator #59 blacksnaponModeratorStaff member9,461301 waynesville,mo. 3 bolts in ps pump
Jun 22, 2012 Moderator #60 blacksnaponModeratorStaff member9,461301 waynesville,mo. 2 bolts, 2 nuts and remove alt wires, then entire bracket
