Yeah checked all the grounds yesterday, anybody have any experience with noid lights? I got them to light up but not very bright?
I just use a led marker lamp as a noid light Andy - anything i've tested with it lights up pretty bright ..... i can't remember if you've swapped out the ecu or not but reading my manual there should be a ground supplied to turn on the fuel pump relay when the key is turned on - in that link i posted earlier there is a diagram that describes the wiring circuit for the fuel pump relay . This will tell you which wire should have this earth on from the ecu.
I know you've bypassed the relay to energise the fuel pumps but i can't help wondering if the ecu is crook ..... i'll test my truck when i get to work shortly and let you know what the voltage is at the injectors.
Have you tried pulling codes from the truck Andy?
