- 55
guys a charging issue has occured on my 79 F250 460, 65amp alt.{new duralast from autozone & new regulator}up to this point the vehicle was charging on its own & all was fine.ive been driving it short distances to get to know the vehicle & work out the bugs so to speak,its only been running about a month.i have noticed that sometimes there is a delay of 10 sec when you turn the ign. key to crank it over it will delay then crank & start up.other times it will crank right up.once the engine fires & starts,while its running my volt meter shows a discharge condition.by a jiggle of the ignition key {switch is dash mounted}the voltmeter will rise & the truck will charge the system....well after sitting about a week i got in her cranked it up it started fine but is no longer charging,i tried my jiggle trick & no good.i took the alternator back to the store and it was tested several times & it checks out good,the regulator is also brand new.i see no corrosition at the pigtail of the regulator,the wires appear soft & bendable.same with the alternator wires & there is power going to the alternator.any ideas? could there be a fault in the ign switch causeing this?my electrical diagnosis skills are weak.suggestions would be very helpfull..thanks..Bob
