Stoner Dan
California Chapter member
Hey, y'all--
So, I've been thoroughly LOVING my "new" '74 SCS, but I'm afraid I may have run into a problem that might be worth several hours of heartache...
I was pulling up to a stop sign that's at a slight right curve in the street. Hit the left turn signal, but I have to turn the wheel to the right to pull up to the stop.
The self-return on the signal triggered as I turned the wheel to the right, so I absent-mindedly held down on the turn signal arm and I heard a little click. Now, the turn signals don't work at all. No lamp, no relay/ballast sound, nothing.
I changed the relay/ballast, but that didn't fix the problem. Did I break something in the column? Has anyone run across this problem?
