BKW
Ford Parts Guru
The three step scenario of a failing DuraSpark ignition module:
1) Module overheats, engine dies. Module cools down, engine restarts almost at once.
2) Module overheats, engine dies. Module cools down, engine restarts in an hour...or so.
3) Sooner or later, usually sooner, the module overheats, BURNS OUT. Now the engine will not restart.
Since the module only fails when it overheats (Ford techs refered to DuraSpark on vehicles of this vintage as NeverSpark!), taking the little charmer to an autoparts store to be tested usually doesn't work, unless it has failed all together.
Inside the dizzy is the stator (aka magnetic pickup coil). The symptoms can be exactly the same as the module.
Most autoparts stores in today's world sell modules that are made in China CRAP! Some of these are defective right oughtta the box.
Replace with a genuine Motorcraft module, ditto for the stator.
Look on the module...above where the wires feed out for the colored plastic square, which ID's which module you have...as there were several different types used 1976/79.
The most common is the blue module, but if the vehicle was sold new in CA, the module might be red, blue, or brown.
The same stator (D4PZ12A112A-Motorcraft DU1A) was used 1974/79 on all V8's (except 1979 LTD's w/EEC & 351W's sold new in CA).
