79460f100
Moving on
have you ever heard of anybody using an air conditioner condenser as a auto transmission cooler ? One that is used but clean inside.
You all really think oil will flow through an A/C condensor efficiently enough to actually work? I think not and if you try it you'll regret it.
An AC condensor is where refrigerant is converted from a gas to a liquid. I'm not understanding how you all think transmission fluid will flow through it efficiently enough to cool it. If anything, It seems as it would be restrictive, creating pressure which would lead to leaks elsewhere in the loop and more heat rather than cooling. And I have an after market transmission cooler and the fins are totally different. If the OP tries it, please give us some feedback and let me know if I'm FOS...
