A buddy of mine said that you can take the front suspension off an f250 and put it on a f150 andfit bigger tires. I am talking about 94 or so model. Is there any truth to this, if so what parts can be used?
I know it can done, I've seen it. As far as I know, you'd need absolutely everything. You'd be going from coils to leaves, yadda yadda yadda. If I were you, it would be easier and probably cheaper to just get a lift.
To quote the"""pig""" going to the trouble solid axle it.
The F350 2x4 coils r good for . 1"-1 1/2" over a set of F150 new coils . But I've seen fronts sag so bad that the F350 coils raise front 3" . Most good Alinement shops (not mega shops) had HD chamber kits to Fix the slight \ / You might get . Or the lift manufacturers have them .
