Mr. Stroker
CASE IH
What trans were available in a 92-96 F150?
where's the AOD in that list Conner?
Now you are the WRONG one Both the AOD and the AOD-E are 4-speed (3 + overdrive) transmissions. The AODE was just a later version that incorporated more electronics. And I believe that the AODE and 4R70W essentially the same transmission (if not EXACTLY the same transmissions).huh uh the AOD is the un overdrived version of the AODE...and far as I know (because parts are interchangeable)the E4OD is the overdriven version of the C6.
to clarify on the m5od, wasn't it more specifically the m5od-r2. not sure where the r1 fit in
1992– AOD-E — Electronic AOD
1993– AOD-EW/4R70W — Strengthened AOD-E with lower 1st and 2nd gear ratios
1966–1996 C6 - Most big-block V8 powered cars of the 1960s and 1970s in the North American market
1985–1994 A4LD — C3 with overdrive
1989–1996 E4OD — C6 with overdrive
1995–2001 4R44E — Electronically controlled A4LD, light-duty
1995–1997 4R55E — Electronically controlled A4LD, heavy-duty
The main difference between the AOD and the AODE is the fact that the AODE has the selectable od on the end of the shifter in the form of a button...unlike the AOD which has it marked on the column.Example. AODE : P-R-N-D-2-1 /AOD: P-R-N-D-3-2-1
LOL! So does anyone really even know? I was thinking they offered two autos (E4OD and the AOD) Plus the manuals. But a buddy of mine swears he has a 4R70W in his 94 F150...
