dreamison
Texas Chapter member
Hello,
I am finishing up a MAF conversion on my 91 f150 5.0 4x4 With E4OD. I am using a computer from a 95 bronco its a WAY1. My problem has to do with the O2 sensor. According to ford fuel injection website I have a 3 wire O2 sensor but mine is actually a 4 wire. Also according to them the 95 has dual 4 wire O2 sensors. I was planning to split the signal from my single sensor into the two pins #43 and 44 in my eec connector. the problem I am running into is that on the wire diagram for the 95 truck they show two sensors running to pin#43 and 44 but on the pin out sheet they only show the O2 signal going into pin #44. Its simple enough to split it into the two pins however pin #43 on my 91 connector already has a solid purple wire in it. I cant seem to figure out what this wire is as there is no reference to it on the wire diagram and the pin out sheet for 91 shows it empty. Does anybody know what this wire is? I tried to trace it back and it runs into the harness towards the radiator. Any help sorting this out would be appreciated.
